LabWindows/CVI
Unable to pass AI value to log file
I have a problem passing an AI value from a Fieldpoint module to print out to a log file. However I'm able to pass other values from a second panel on the UIR.
Is there something I'm missing or should I take a different approach when dealing with FPAdviseCallback function?
void CVICALLBACK FPAdviseCallBack(void* buffer)
IAByte* Databuffer;
FP_CallbackParamType g_param;
float* value;
int i,j;
/* See the Function Panel FP_Advise item "Callback Function" for more information
on this callback and it's data types*/
g_param = *((FP_CallbackParamType*) buffer);
Databuffer = g_param.buffer;
value = (float*)(Databuffer);
SetCtrlVal (panelHandle, PANEL_AI0, *value);
value = (fl
oat*)(Databuffer+4);
SetCtrlVal (panelHandle, PANEL_AI1, *value);
int CVICALLBACK configureUSER(int panel, int control, int event,
void *callbackData, int eventData1, int eventData2)
switch (event)
case EVENT_COMMIT:
SetCtrlVal (panelHandle, CONFIGURE_USER, User);
GetCtrlVal (panelHandle, PANEL_USER, User);
int CVICALLBACK logFilebutton(int panel, int control, int event,
switch (event)
case EVENT_COMMIT:
FILE * logFileptr;
/* Write to file */
logFileptr = fopen ("c:\\logfile.txt", "a");
fprintf (logFileptr, "\t%.2e", User);
fprintf (logFileptr, "\t%.2e", PANEL_AI0);
fprintf (logFileptr, "\t%.2e", PANEL_AI1);
fclose(bakeoutLogFilePtr);
The FpAdviseCallBack and configureUSER functions works fine in displaying the values in the panel. When I exectute the logFilebutton function it is able to write to the file but the "PANEL_AI0 and PANEL_AI1" send
values from their #define values. The "User" string in the log files works fine.
(2,945 Views)
In order to pass to the log file the value stored in the control instead of its ID you must retrieve the value in a variable with GetCtrlVal before outputting it to the file.
Another way could be to use two global variables (like User in your function, that is not defined elsewhere so I assume it's defined at module- or project- level) and store in them the values read from fieldpoint in FPAdvise; you can use them next in the program as you need.
Roberto
(2,945 Views)
