LabWindows/CVI
Undefined symbol '_Timeout_Config
If it helps here is the easyio.h
Message 11 of 13
(1,318 Views)
I think I found the problem,
I don't think it was finding the correct libraries I added easyio.lib, and dataacq.lib to the build manually and it compiles with no errors. I'll check it with the actual device to see if it works completely.
Thanks again for your help Roberto,
Michael Eller
Message 12 of 13
(1,314 Views)
Accepted by topic author meller
That's exactly why I suppose there is something wrong in your installation: not sure about easyio.dll, but you should not need to add dataacq.lib to your project, the system should be able to find system libraries by itself. Anyway I'm happy you succeeded in solving your problems.
Message 13 of 13
(1,307 Views)
