LabWindows/CVI
Undefined symbol '_niDMM_ConfigureMeasurementDigits' referenced in
I am getting the message below when I compile an old written code.
     "hardware.c"
Here si the part of the code in hardware.c
// set DMM to requested configuration
if((error=niDMM_ConfigureMeasurementDigits(dmm, mode, range, digits))
!= VI_SUCCESS) {
niDMM_error_message(dmm, error, errorMsg);
MessagePopup("Equipment Error", errorMsg);
return 1;
please help
Thank you
Message 1 of 8
(4,451 Views)
Have you included the library (in your project) where the function _niDMM_ConfigureMeasurementDigits is contained?
Message 2 of 8
(4,431 Views)
Thank you Ray,
I mess up the setting from the library option or other because I am getting new error message:
please advice:
Regards
jaime
Message 3 of 8
(4,406 Views)
That should be easy to fix.
You have declared a macro 'MAKEINTRESOURCEA' & 'MAKEINTRESOURCEW' somewhere in the code already (or in one of the libraries?).
In any case.  If they are the same macro, simply comment out where they are redefined in lines 37 & 38 of winver.h.
It's better to comment out at this time, in case they are not the same macro and functionality becomes erratic.
Hope this helps,
R
Message 4 of 8
(4,401 Views)
Jaime:
Redefinition errors are often due to problems with your #include statements.
Sometimes #include statements are position sensitive.  Try changing the order of the statements, like moving windows.h up in the order.
Make sure that you're including the CVI version of the SDK (WinAPI) .h files, not a Visual Studio version.
The file windows.h includes winver.h.  In your .c files #include only windows.h.  Don't also #include winver.h.
Regarding your original error, did you verify that you have the .lib file for nidmm as part of your project?
You may need to install the driver.  See the link here: http://joule.ni.com/nidu/cds/view/p/id/442/lang/en.
Message 5 of 8
(4,374 Views)
I got the project compiled, but now I got an error window message
this file is in the window/system32 folder.
Please advice
Thank you all
Message 6 of 8
(4,369 Views)
What version of NI-DAQ do you have installed?  (Go to Start >> Programs >> National Instruments >> NI_DAQ)
You may need to reinstall it.
Message 7 of 8
(4,361 Views)
version 9.0.2
Message 8 of 8
(4,359 Views)
