LabWindows/CVI
Undefined symbol '_set_pts' referenced in "new.c".
Hi, this code works in other compilers such as Bloodshed, and even runs fine when I use the command line.  However I need it to work in CVI... here is where new.c references set_pts:
#include <stdio.h>
#include <ctype.h>
#include <spinpts.h>
#include <ansi_c.h>
int spinpts300(double frequency, int phase)
 PTSDevice PTS300;
 PTS300.mfreq = 300.0;
 PTS300.allowPhase = 1;
 PTS300.fullRange10MHz = 0;
 return set_pts(frequency, phase, &PTS300);
and here is where spinpts.h calls the function:
 #ifdef WINDOWS
 #ifdef DLL_EXPORTS
 #define SPINPTS_API  _declspec(dllexport) __stdcall
 #else
 #define SPINPTS_API  _declspec(dllimport) __stdcall
 #endif
 #else
 #define SPINPTS_API
 #endif
SPINPTS_API int  set_pts( double frequency, int phase , PTSDevice* device );
I have already generated DLL import libraries for the .h
(3,346 Views)
And of course you have added said libraries to the project...
JR
(3,344 Views)
Yes I generated import libraries since I am using DLL's.
(3,341 Views)
Hi smckeonn,
Jonathan brings up some other things to consider in this thread:
http://forums.ni.com/ni/board/message?board.id=180&message.id=29343&requireLogin=False
You may want to double check you calling convention, as described in this KnowledgeBase article:
Link Error When Calling a DLL in LabWindows/CVI
http://digital.ni.com/public.nsf/allkb/6A7825928D19C5318625714C006CEEC7?OpenDocument
John B.
Message Edited by NI-Bongo on 06-26-2008 10:13 PM
John Bongaarts
(3,303 Views)
