LabWindows/CVI
Undefined symbol
Hello!
I try to build a simple adder CIN. But when i build the file i get "undefined symbol GetLVSBHeader referenced i my add.c". What is it am doing wrong?
I did even try to build the "add.vi" project from ni.com with the same result.
Geir Trana
(3,801 Views)
Hello Geir!
Are you still experiencing problems when creating a CIN in LabWindows/CVI for later use in LabVIEW?
Please make sure that you follow the steps found here:
http://digital.ni.com/public.nsf/websearch/F324F21A22634836862569B30070B5E9?OpenDocument
Also this manual is very helpful and includes numerous tips:
https://www.ni.com/docs/en-US/bundle/370109b/resource/370109b.pdf
Hope this helps!
Jimmie A.
Applications Engineer, National Instruments
Jimmie Adolph
Systems Engineering Manager, National Instruments Northern European Region
(3,767 Views)
Hello!
I does not get the CIN to work. I get the same error every time i try to build it.
Thanks for your help.
Geir
(3,731 Views)
