LabWindows/CVI
Undefined undefined symbol _Ibsta@0
I am getting the link error (Undefined symbol '_Ibsta@0' referenced in "gpib_test_1.c"). I am using Labwindows/CVI to interface with a Ruska 7250 model Pressure sensor using an NI-488.2 GPIB-USB-HS connector.  The code that I have is basically copy/pasted from the NI-488.2 User Manual. There are no real compiler errors besides this link error. Any help in resolving this is appreciated. Thank you.
(3,855 Views)
This kind of error is usually related to a missing library: have you installed ni488.2 product? And have you checked the corresponding library in Library >> Customize menu?
(3,830 Views)
There is no function Ibsta() in the GPIB libraries.
There is, however, a global variable called ibsta - is that what you were looking for?
Martin
Certified CVI Developer
(3,809 Views)
Yep, using the global variable instead of the Ibsta() function call in the manual seems to have worked. Thanks!
(3,790 Views)
