LabWindows/CVI
Underline a column in a table
I am using a tabl eto display values which is read from the SQL server database. I want to change the color and underline the contents in column 1. Kindly let me know how I could do this programatiically.
Thanks!
Chathuri
Message Edited by Chathuri on 05-05-2009 10:38 PM
(3,548 Views)
Attributes of existing cells can be changed individually via SetTableCellAttribute or in a block via SetTableCellRangeAttribute and choosing the appropriate attribute to set. Since you want to affect an entire column, you must use the second instruction and can use the macro VAL_TABLE_COLUMN_RANGE (column) to select the correct area.
(3,540 Views)
