LabWindows/CVI
Understanding DAQmx Functions
Hi ,
I have a few questions regarding the DAQmx Library in CVI.
1.While working with DAQ Devices I'm opening a Task and a channel to some device For example AO1.
I'm setting it to work with an external hardware trigger and defining all the needed parameters , starting the task doing the analog output and stopping the task.
so far so good , but if I want to repeat the same task without setting all the parameters again how can I do that ? Does the device remember it's configuration ?
the thing I need is to make a task that will repeat it self for days with out setting parameters because it takes time from each test,  time I don't have.
2.NI Function time cycle , is there any document that show how much time it takes for each function ?
3.  DAQmxErrChk (DAQmxCreateAOVoltageChan(gAOtaskHandle,AOchan,"",AOmin,AOmax,DAQmx_Val_Volts,NULL));
the values for AOmin & AOmax : if I'm setting it to -10 : + 10 , is it possible to change it with out creating a new channel ?
Kobi Kalif
Software Engineer
(4,131 Views)
As per your Q1, provided you do not clear the tast you can start and stop it many times. I have used this method for digital output: I suppose it is the same for analog output.
(4,127 Views)
Hi Roberto ,
Iv'e tried it , it works fine.
Any idea about my other questions ?
Kobi Kalif
Software Engineer
(4,121 Views)
While I have no idea about your second question, I suppose you can use DAQmxSetChanAttribute with DAQmx_AI_Max and DAQmx_AI_Min attributes respectively. I have no DAQ device at present to make a real test and see if changing these attributes with the task started raises any error or actually does not changes settings at all (that's why I didn't post this before), but you can try it in minutes.
(4,118 Views)
You right it's work fine , i didn't knew if it's ok to change this val while running but it's ok.
As to Q2 i'll test is myself with the PC Clock or the timer.
Thank you.
Kobi Kalif
Software Engineer
(4,110 Views)
