LabWindows/CVI
Unexpected "KeyboardHookDll" usage
Hi all,
I have just noticed that in debug window of my projects some lines are appearig regarding a "KeyboardHookDll" which I'm not aware of. Even with a simple project that opens a window and closes it by a button I get the following lines in the debug window:
When starting the project (before the "break on first statement" option interrupts code execution):
 KeyboardHookDll DllMain called
 KeyboardHookDll DllMain DLL_PROCESS_ATTACH called
 KeyboardHookDll ShellHookFunc called
When pressing "Exit" button:
 KeyboardHookDll DllMain DLL_PROCESS_DETACH called
I never observed those lines before (I usually use extensively the debug output window when debugging projects I work on) and I am not sure why they started appearing now. They are appearing on CVI 6.0, 7.1 and 8.0 projects regardless the composition of such projects.
Anyone hase some idea about them?
(2,740 Views)
Forget it!
These lines appear only when I'm running MusicMatch Juxebox media player to hear some music while working... Smiley Surprised
Wew! I was beginning to suspect to have been infected by some unknown virus not detected by firewall and antivirus... Smiley Happy
(2,735 Views)
