LabWindows/CVI
Unit Test Framework for CVI
While there may exist a unit testing framework in LabView by NI, there is unfortunately none provided for CVI.   Has anyone had any experience with using other frameworks such as Test Complete or C Unit test frameworks with CVI?
(6,839 Views)
Gosh Steve, what a great question. What about Check? I haven't tried it yet, but since it's for C, it seems like it should work for LWCVI. http://check.sourceforge.net/
I do hope someone will provide us a definitive answer.
My son who is working at Oracle, doing Java programming, has told me about unit testing for years, asking me if I did unit testing when I mentioned that I had bugs in my C or LabWindows code. I always told him "sure, my code passed all my unit tests" but not wanting to spend the time to learn about unit testing and see if it could be applied to CVI.
Good luck,
John
(6,827 Views)
Steve:
Maybe CUnit is more appropriate for LWCVI? Check seems a bit complex to use, using Autotools. I haven't tried CUnit either, just now reading the documentation. http://cunit.sourceforge.net/
(6,817 Views)
Hello John and Steve,
Have you had the chance to try Check or CUnit with CVI projects? What were the results?
Anna
(6,111 Views)
the mentioned CUnit frameworks works well in LabWindows CVI. It is in use since several years without any problem.
Cake
(5,862 Views)
i know your answer is three years old, but can you explain how to integrate cunit in cvi?
(4,837 Views)
Gosh, I had never tried Cunit and had completely forgotten about it. Sorry.
John
(4,831 Views)
