LabWindows/CVI
Unknown size of type pointer to __cdecl voidfunction(int)
What does this error mean?
I have:
double *data=NULL;
double *pointer=NULL;
double *ini=NULL;
double array[10][10];
data=malloc(100*sizeof(double));
pointer=data;
ini=data;
ReadAnalog.......
array[1][1]=*pointer;
Error
(4,018 Views)
Hi Leee,
can you please more specify the error you get?
Abduelkerim
Sales
NI Germany
(4,000 Views)
i have solved it already. Thanks anyway. But Is ist possible while writing a txt file to read it´´from it salmontaneously?=
(3,994 Views)
Hi Leeee,
thank you for your post.
Usually, if you have configured your txt file that it is possible to read and write simultaneously it should work.
But you should have a look that for example, if you want to read from line 10 but it does not exist, you will of course get an error.
Abduelkerim
Sales
NI Germany
(3,992 Views)
