LabWindows/CVI
Unrecoverable Internal Error at 001B:100F27F1
Other users and I (at the company we work at) have been receiving this error occasionaly that is stated in the subject line. Its occurance is never consistant (one time we will recieve the error when we do the following sequence of events, then the next time we won't receive the error). The only consistantcy of this error is that it seems to only occur when the user is running code, then hits a breakpoint, then the user clicks on the CVI stop button which is Ctrl+F12, then the user tries to run the project again with a shift+F5, this is when the error will popup, if and when it does. We are running Labwindows/CVI version 5.0.1.
If you have encountered this same error or have any suggestions on what may be causing this error
please respond.
(3,108 Views)
Hello Ethan,
I recognized the patern because I have had this same error in the past, quite often and still have it from time to time.
Based on my observations, it tends to happen only on exceptional ocassions. It seems difficult to replicate and one thing that I learned is to STOP the applilcation anytime I want to make changes. (However, I keep forgetting about it and therefore the error keep reapearing) At least in the version I am using now, the application shuts down in a rather orderlly fashion -now I am using version 5., prior to this one it made a mess on the application everytime that it happened!-
Well, sorry for the long answer. My best advice, like I said is to don't try to modify the UIR or code while the application is on HOLD from debugger or runt
ime errors. Ofcourse, the other option is to share your code with NI technical staff. For me, that is not an option due to the nature of my R&D confidentiality.
(3,108 Views)
