LabWindows/CVI
Unrecoverable Internal Error at 0023:100A41DE
I have a problem when I try to create a Distribution Kit in Labwindows CVI 9 on Windows 7.
When I try to open Manage Distributions, the following message appears:
"Unrecoverable Internal Error at 0023:100A41DE. Labwindows/CVI will be aborted".
Labwindows/CVI is closed.
When I try to open "Edit..." in distributions, the same message appears.
I can't create a new distribution kit and so edit it.
Can you help me please because it's very blocking?
Thank you.
Best regards.
Karine.
(5,232 Views)
Hi Karine,
in the past I could resolve this inconvenience by copying and editing an .cds file from an earlier distribution (see here)
(5,229 Views)
Thank you, but this solution doesn't resolve my problem...
Have you another solution please?
Thank you.
Best Regards.
Karine.
(5,221 Views)
No, unfortunately not - since it did work for me I did not explore other options.... So probably you should proceed as suggested by Mert_A in the forum thread I have linked to.
(5,218 Views)
Hi Karine,
Could you zip up your project and .cds file and upload them? Maybe you cannot post your project, then the failing .cds file could still be helpful. Also, a debug log might have some information that would help us.
Romain P.
National Instruments France
(5,193 Views)
that's exactly the suggestion I referred to...
(5,188 Views)
