LabWindows/CVI
Unrecoverable Internal Error on launch
Hello all,
just trying to open an oldish (cvi2013) project with cvi2015 and it crashes without even showing the cvi window with: "unrecoverable internal error at 0023:10AFC318. LabWindows/CVI will be aborted"
I remember there was some utility you could run and configure to diagnose CVI crashes in a log file, but I cannot find it.
Also I checked the cws and prj file and I don't see any garbage or potential problems with them.
(2,579 Views)
It was a small project, so I just deleted the .prj and .cws and reimported the source files into a new project. Still, it's annoying to have crashes like that and no hint as to what the problem may be.
(2,551 Views)
