LabWindows/CVI
Unrecoverable internal error
I have a "Unrecoverable internal error" (001B:101A3816) when i try to built project. The only change i made is i add 2 header files (ifcapi.h and ifc.h) that call io.h and fcntl.h. Does anybody has a idea?
Thank you
Steph
(3,690 Views)
Hello
Which version of CVI are you using? Could you post the project so I can try to reproduce this on my machine. I can ry it out with CVI 7.1 to see if the problem still exists.
Bilal Durrani
NI
Bilal Durrani
NI
(3,690 Views)
I use CVI 5 or CVI 7.0 : same problem.
Sorry but i can't send my project.
Thanks.
Steph
(3,690 Views)
If you can replicate this on a smaller scale, that might help instead of sending your entire project.
Or if you do not want to post the project on the public forum, you could post your email and I could get in touch with you offline.
Bilal
Bilal Durrani
NI
(3,690 Views)
