LabWindows/CVI
Update canvas with a background bitmap?
I have a large bitmap file (a map) I want to use as a background in a canvas control and I need to update the location of several smaller bitmaps on the same canvas without having to redraw everything (especially the large image) every time. I tried several methods, but when I move one of the smaller bitmaps they always leave a "hole" (white background) in the larger bitmap so I end up having to redraw everything. Any help would be greatly appreciated.
Haris
(3,304 Views)
Haris
When you update a canvas with a new bitmap, the canvas does not remember what was previously on it.
I would suggest using a graph instead of a canvas. By using a graph, you can do what you are wanting.
Let me know if you have any difficulties using a graph this way.
Brian
(3,304 Views)
Thanks Brian.
I already tried your approach and it worked. The canvas is faster so I was hoping that I could do it with a canvas instead of a graph. Thanks for your help.
Haris
(3,304 Views)
