LabWindows/CVI
Update to Windows 11 causes inconsistencies on Timer () value
Hello all, I have an application that has been running from several years now without major issues. Now the customer has updated one of his systems from Win10 to Windows 11 (version 24H2, build 26100.6899) and the application has started to raise strange errors that seem to originate on the value returned by Timer () function.
The application is a multithreaded app developed in CVI2017 and running in dozen of applications with PCs from different brands. The issue originates in a thread spawned from the main thread by means of
	cmtErr = CmtScheduleThreadPoolFunction (DEFAULT_THREAD_POOL_HANDLE, TestSurvey, NULL, &threadID);
	if (cmtErr < 0) {
		line = __LINE__;
		goto Error;
The skeleton of the thread function is this one:
int CVICALLBACK TestSurvey (void *functionData)
	static int  onTest = 0;
	double      tini = Timer ();
	while (!endThread) {
		xt = Timer ();		// <=== Save Timer () value
		if (((xt - tini) > (testTime * 1.2))) {
			// Warn a sync alarm with remote device
		if (GetInQLen (com) >= 13) {
			// Read and decode messages from the remote device
			comChk (ComRd (com, msg, 13));
			// Dump messages to disk together with 'xt' variable
			// Process remote device data
			// At test start:
			if (!onTest) {
				// Do stuff
				tini = Timer ();
				onTest = 1;
			// At test end signaled by remote device:
			onTest = 0:
Loop:   ;
Error:
	// Clean up stuff
	return 0;
As you can see, on each iteration I save Timer () value and originate a warning if the remote device does not send a test end signal within expected test time + 20%.
I also note down all messages received from remote device together with internal variables values including 'xt' which holds the Timer () value saved previously.
By examining those raw data I see that Timer () value has inconsistent jumps in value not related to expected thread looping time (and surely not coherent with the real operation of the machine). Here is an abstract of raw data file which evidences the anomaly (Timer () lies in the column following '0d' values):
0x31 0c 8c 00 00 00 00 02 0c 7d 00 14 0d 133144762.66 128849795.31 5.0 - 49 2956 0 0, 2 3197 20
0x31 0c 8c 00 00 00 00 03 08 94 06 11 0d 133144762.72 133144762.66 5.0 - 49 2956 0 0, 3 1940 1553
0x31 0c 8c 00 00 00 00 04 07 fd 07 49 0d 133144762.79 133144762.72 5.0 - 49 2956 0 0, 4 1789 1865
0x31 0c 8c 00 00 00 00 05 08 03 07 31 0d 133144762.79 133144762.72 5.0 - 49 2956 0 0, 5 2051 1841
0x61 00 00 07 fd 00 00 00 39 fb ad ec 0d 137439730.11 133144762.72 5.0 - 97 0 1789 0, 0 30/10 15:56:57 <<== ***
0x31 0c 8c 00 00 00 00 05 07 ed 07 3d 0d 137439730.11 133144762.72 5.0 - 49 2956 0 0, 5 1773 1853
0x46 0c 73 06 d6 07 53 64 0c d7 00 00 0d 137439730.83 137439730.83 5.0 - 70 3187 1494 1875, 100 3031 0
0x31 0c 8c 00 00 00 03 20 00 00 00 04 0d 158914568.64 133144762.72 5.0 - 49 2956 0 3, 32 0 4
0x31 0c 8c 00 00 00 03 20 00 00 00 04 0d 158914568.66 158914568.64 5.0 - 49 2956 0 3, 32 0 4
As you can see, in the highlighted row the timer value is 137439730.11 with a jump of over 4-million-seconds from the previous record !! This fires the sync error which is causing lots of troubles to my customer.
Now questions are:
  • Has anybody observed a similar problem?
  • What can be causing this?
  • Will other methods to check time value be affected as well (e.g. GetTickCount() SDK function) ?
  • Can updating to a more recent run-time engine patch this problem?
(130 Views)
According to documentation the timer attempts to use the performance counter timer if the useDefaultTimer is set to False.
Personally, I created my own timer using QueryPerformanceCounter() (SDK) a long time ago.
You can increase the priority of the thread.
You can use callback instead of pulling data frequently making the thread more CPU friendly
It is important to remember that Windows OS is not a real-time operating system. Your thread is not guaranteed to have full attention all the time.
Jan
(110 Views)
Hello Gaus, thanks for your response.
In my application test is driven by the remote device and I'm using Timer () only to roughly detect when its stops operating: in this respect time precision is not a problem. It's crucial not to incorrectly raise a wrong alarm, instead.
Did you ever observed any problem in using QueryPerformanceCounter ?
(82 Views)
Hello
I have not observed any problem with the QueryPerformanceCounter () as such. For most of the time it has been used to test how much CPU time software routines consumes.
When variable CPU speed was introduced years ago, there was some notes that these timer routines were not aware of the speed change and produced wrong results. I guess that this has been fixed for modern OS and SDK.
(63 Views)
Since as you said Timer () relies on Performance Counters or multimedia timers I decided to develop an alternative approach based on GetTickCount (). It is now on the way to be installed on customer equipment: I'll let you know if it behaves well.
(23 Views)
