LabWindows/CVI
Urgent-UIR files can't be loaded whn Resolution Changes
         I have an application that works well on Windows XP with Screen Resolution 1600x1200.Whn I copied the application to another PC with another resolution it is not working.The property Resolution Adjustment on all the uir files files in my project is set to 100 and Sacle Contents on Resize is checked.But still i'm not able to load some uir files.The height and width of these uir files(which cannot b loaded) are set to 1600 and 1200.Is this a problem y the files r not loaded.Later I changed the resolution of the new machine to which I copied the application to 1600x1200.Still it is not working.Can anyone give a suggestion.Its urgent.
  mala
(3,202 Views)
           i forgot to mention the Error coming\;
Error is : Error in call to loadpanel.Error Code = -90.Attribute value passed is not valid
(3,203 Views)
Your problem seems more likely due to not copying over the correct/latest UIR file. Any chance you are using a different copy of the UIR?
--Ian
(3,185 Views)
Hello, vava
If you're using CVI 7.0, then this is probably the problem that you're running into.
Luis
(3,175 Views)
