LabWindows/CVI
Use ENTER keypress to close panel
I have an OK button on a panel that does some processing of the data entered within the other controls and closes the panel. I would like the panel to have the same look and feel as a Windows panel in that when ENTER is pressed, no matter what control is selected, the OK button event is carried out.
(3,184 Views)
To do that, all you have to do is assign the ENTER key to the OK button as a shortcut key. You can do that when you edit the command button in the UI editor, or you can do it programmatically with the following call:
SetCtrlAttribute (panel, control, ATTR_SHORTCUT_KEY,VAL_ENTER_VKEY);
Luis
NI
(3,184 Views)
Of course! Thanks for that.
(3,184 Views)
