LabWindows/CVI
Use external clock (PFI2) with Traditional DAQ
Can figure out how to specify the external clock line (PFI2) while using Traditional DAQ (7.4.2f3).
Can anyone help?  TIA.
George
George Zou
(4,138 Views)
I never used such a configuration but I found an example that will probably be helpful for your problem: it's named SCANsingleBufExtScan and you will find it in samples\daq\ai folder on your hard disk.
(4,127 Views)
Thanks for reply.
In that example, it doesn't tell me how to use PFI2 pin as external clock.  It only tells me: "Also, connect a digital pulse train to the 'external scan clock' pin. (NOTE: This is NOT the pin labelled "SCANCLK" but instead is a counter output pin.)
A counter output pin?  What is the pin #?
George Zou
(4,117 Views)
I have a similar application where I use this:
    Select_Signal(Board, ND_IN_SCAN_START, ND_PFI_2, ND_LOW_TO_HIGH);
to specify PFI2 as external clock source.
to find the correct pin for PFI2, refer to the manual of your DAQ device.
Once the game is over, the king and the pawn go back into the same box.
(4,101 Views)
This helped me determine which pin to use for my external clock signal to trigger from PFI2:
http://digital.ni.com/public.nsf/websearch/39F8242E2553F63E86256FE3007BF69F?OpenDocument
(3,485 Views)
