LabWindows/CVI
Use/incorporate CSS on Labwindows UI for beautify the interface?
Hello!
I'm using Labwindows to create small test programs, but I would like to make their interfaces more beautiful and modern. I ask you if it is possible (and if so how) to insert CSS code into the UI programming to create more attractive button controls or even small animations with filling effects. Or if not what could I do.
Thanks in advance!
(1,497 Views)
CVI panels and UI objects are in a proprietary format that cannot be customized with style sheets or in other ways. The only possibility you have to modernize your UI (whatever that means) is to use built-in tools and features in a creative way.
Some people out there have suggested to try integrating CVI code with more up to date UI development environments but this is a path that you will have to follow with very few companions and even less documentation. Anyway, there are a few discussions you may want to search and read on this: this one for example can offer some interesting starting point.
(1,447 Views)
