LabWindows/CVI
Use of ANSI-C "qsort" function?
Hi.
I would like to sort some short integers using "qsort".
CVI returns an error message "Type error in argument 4 to `qsort'; calling convention mismatch.". I am using CVI 5.5.
I also tried some example code pieces that worked with gcc and mcc, but CVI compiler returns the same error.
A strange convention or a bug?
Thanks, Matti
Sort command:
qsort ((void *)input, (size_t)num, (size_t)sizeof(short), CompareShorts);
Comparison function:
int CompareShorts(const void *element1,const void *element2)
short *a1,*b1;
a1=(short *)element1;
b1=(short *)element2;
return (*a1<*b1) ? -1 : (*a1>*b1) ? 1 : 0;
(3,457 Views)
Duplicate post. See answer here.
(3,457 Views)
Hello
I tried the following code on CVI 5.5 and it didnt return any errors to me, give this a shot:
#include
#include
short input[5]={5,4,3,2,1};
int num=5;
int CompareShorts(const void *element1,const void *element2);
int main (int argc, char *argv[])
if (InitCVIRTE (0, argv, 0) == 0)
return -1; /* out of memory */
return 0;
short *a1,*b1;
//=====end of code==================
Best of luck
Bilal
Bilal Durrani
NI
(3,457 Views)
