LabWindows/CVI
Useage of "MessageBoxEx()"
Hello ,
If using sdk of "MessageBoxEx()" to popup a message , I'd like to know if this would block other task process ?
David
(3,068 Views)
David,
I'm not sure whether MessageBoxEx() will interfere with other threads; I don't think it will, however if you wan to be 100% sure how your popup works, you can just create your own panel and control on what thread is launched; this could avoid you the uncertainty of the SDK call.
Good Luck!
Juan Carlos
N.I.
(3,068 Views)
According to the definitive documentation (here) MessageBoxEx will only block its parent window or windows in its thread (depending on the flags set). I think.
Martin
Martin
Certified CVI Developer
(3,068 Views)
