LabWindows/CVI
Using CVI, how can I get the Path of an application
"Hi, I have developped an application in CVI 6.0, and i have created the Distribution kit. In the application I must create some files that must be in the same directory where the application was been installed. Is there a way for me to know what is the directory path of the application, when it has been installed in another PC different than mine ?"
(2,903 Views)
GetProjectDir in the utility library should do the trick for you.
(2,903 Views)
