LabWindows/CVI
Using CVI libraries in Visual Studio C DLL
I am attempting to enhance a legacy VS 2008 Visual C based DLL to use NI Shared Variable/Network Variable support.  From what I have found in the documentation, it seems to imply that CVI libraries can be imported into an existing VS by using the libraries in the ext/msvc64 directory.  I originally included just the cvinetv.lib file to my linker list.  After reading more of the CVI programmer manual, it seemed to imply that cvirt.lib and cvisupp.lib were also needed.  Under both circumstances, the linker throws a conflict between CVI libary and MSCVRT.  Since this is a legacy project and not a CVI wizard generated situation, I'm wondering if there are more tweaks that need to be done my project settings.  I also found a mention of needing to list "libc" under "Ignore Specific Library".  Doing this made no difference either?
Any help would be greatly appreciated..especially if this approach is not a valid way to take advantage of shared network variables in a standalone DLL.
Chris.
Linker errors:
1>LIBCMT.lib(tidtable.obj) : error LNK2005: _encode_pointer already defined in MSVCRT.lib(MSVCR90.dll)
1>LIBCMT.lib(tidtable.obj) : error LNK2005: _encoded_null already defined in MSVCRT.lib(MSVCR90.dll)
1>LIBCMT.lib(tidtable.obj) : error LNK2005: _decode_pointer already defined in MSVCRT.lib(MSVCR90.dll)
1>LIBCMT.lib(crt0dat.obj) : error LNK2005: _amsg_exit already defined in MSVCRT.lib(MSVCR90.dll)
1>LIBCMT.lib(crt0dat.obj) : error LNK2005: _initterm_e already defined in MSVCRT.lib(MSVCR90.dll)
1>LIBCMT.lib(crtheap.obj) : error LNK2005: _malloc_crt already defined in MSVCRT.lib(MSVCR90.dll)
1>LIBCMT.lib(mlock.obj) : error LNK2005: _unlock already defined in MSVCRT.lib(MSVCR90.dll)
1>LIBCMT.lib(mlock.obj) : error LNK2005: _lock already defined in MSVCRT.lib(MSVCR90.dll)
1>LIBCMT.lib(winxfltr.obj) : error LNK2005: __CppXcptFilter already defined in MSVCRT.lib(MSVCR90.dll)
1>LIBCMT.lib(crt0init.obj) : error LNK2005: __xi_a already defined in MSVCRT.lib(cinitexe.obj)
1>LIBCMT.lib(crt0init.obj) : error LNK2005: __xi_z already defined in MSVCRT.lib(cinitexe.obj)
1>LIBCMT.lib(crt0init.obj) : error LNK2005: __xc_a already defined in MSVCRT.lib(cinitexe.obj)
1>LIBCMT.lib(crt0init.obj) : error LNK2005: __xc_z already defined in MSVCRT.lib(cinitexe.obj)
1> Creating library .\Debug/pil_dlld.lib and object .\Debug/pil_dlld.exp
1>LINK : warning LNK4098: defaultlib 'MSVCRT' conflicts with use of other libs; use /NODEFAULTLIB:library
1>LINK : warning LNK4098: defaultlib 'LIBCMT' conflicts with use of other libs; use /NODEFAULTLIB:library
1>LIBCMT.lib(crt0.obj) : error LNK2019: unresolved external symbol main referenced in function __tmainCRTStartup
(5,884 Views)
What operating system are you using?
Take a look at this forum post: http://forums.ni.com/t5/Measurement-Studio-for-VC/Problems-running-in-CVI-a-DLL-made-in-Visual-c-200...
and this http://digital.ni.com/public.nsf/allkb/302C53649D34035886257114007C1C56
(5,868 Views)
Windows 7 64-bit
CVI 2012
Visual Studio Express 2008
(5,866 Views)
Following 3TTHO2ZW explicitly did not clear up the linker issues.  However, setting it to ignore "libcmt.lib" instead of "libc.lib" did clean up the linker error.  Question is whether this is the valid fix?
(5,861 Views)
Yes the fix is valid, and has been verified with our senior applications engineers.
(5,839 Views)
I wonder if it is possible to some forum admin to mark Christopher's last reply as the solution. I've tested what he suggested, since I was trying to do basically the same thing, and it worked like a charm. Also thanks to Edna-S for confirming the validity of the fix.
Wouldn't it be useful to update document 3TTHO2ZW to include Christopher's findings?
Robst - CLD
Using LabVIEW since version 7.0
(5,647 Views)
