LabWindows/CVI
Using CVI library Callback in Visual C++ 6.0
Hello
I wonder if there is a way to set up VC6 so that I can use Labwindows CVI extensive LIB callbacks. I know I won't have the built-in function help features, but I just want to utilize the many CVI callback functions that I'm familar of (like the CVI RS-232 lib and Utility lib in particular). I'm using CVI 7.1.
Thank you very much for any comments.
Regards
hnguyen
(3,489 Views)
Just use the CVI libs (at least cvirt, cvisupp, cviauto from CVI71\extlib\msvc\) in Your VC6 project as any other lib.
And on the target machine don't forget to install the runtime.
If You want to use UIRs look at the menu at Build >> External Compiler Support...
Hope I could help.
/* Nothing past this point should fail if the code is working as intended */
(3,477 Views)
Most libraries will work in MSVC without any problems, provided you add the paths to the include and library directories for CVI in your environment settings. The ones that have problems are the some of the common runtime libraries. For more information, take a look at this forum thread. Hope this helps!
Jeremy L.
(3,461 Views)
Hello
It works. You all make my day. Thanks
hnguyen
(3,451 Views)
