LabWindows/CVI
Using EasyTab functions
I am using CVI Ver6.0.
I have an application that creates a main panel with a Tab control created using the EasyTab functions.
Most of the information about the application is defined in a file and therefore each of the Tab Panel are created dynamically such as;
for(n=.........)
tab_panel[n] = NewPanel(main_panel, ......);
I then add the tab panels using
switch(numOfPanels)
case ONE_PANEL:
EasyTab_AddPanels(main_panel, tabCtrl, ONE_ROW, tab_panel[0], 0); // add one panel
break;
case TWO_PANEL:
EasyTab_AddPanels(main_panel, tabCtrl, ONE_ROW, tab_panel[0], tab_panel[1], 0); // add two panels
break;
......//add more panels
At the moment my switch statement limits the number of tabs added.
Is there a way to make the statement EasyTab_AddPanels(main_panel, tabCtrl, ONE_ROW, ....) my dynamic so that I can get rid of the switch statement.
Regards
Ray Farmer
Regards
Ray Farmer
(4,103 Views)
Hi Ray,
you could design a variable params functions using va_start, va_arg and va_end macros.
Your function could be as follows (it's pseudo-code, so you'll have to debug a little):
int AddingPanels (int *panels)
int myPanel, error = 0;
// Initializa variable-params
va_start (ap, panels);
// Add your panels
myPanel = va_arg(panels, int);
while (myPanel > 0)
errChk( EasyTab_AddPanels (panel, easyTabCtrl, row, myPanel, 0));
sheetPanel = va_arg(panels, int);
Error:
// End variable-parms
va_end (panels);
return error;
The calling function (assuming you want to load 3 panels):
// Load the panels in memory
panels[0] = handle0;
panels[1] = handle1;
panels[2] = handle2;
panels[3] = 0;
AddingPanels (panels);
Hope this helps
Roberto
(4,089 Views)
Hi Roberto,
I did think about using this, but for some reason I had in mind that you had to add all the panels at one go.
Now that thought has been erased and I can do repeated calls of
EasyTab_AddPanels (panel, easyTabCtrl, row, myPanel, 0);
I have used a simple for loop and everything works a treat.
Thanks for the help
Regards
Ray Farmer
Regards
Ray Farmer
(4,068 Views)
