LabWindows/CVI
Using LabWINDOWS developed a simple SW interface to a NI 6533 card. Need to develop the same SW using Microsoft C/C++. Does anyone know of the necessary support files, etc.? Thank you.
Greetings,
You will first want to install support for third party compilers, such as Visual C++. I have linked a Knowledge Base article below which describes how you can do this.
How Do I Install the NI-DAQ Examples for Third Party Compilers (Visual C++, Visual Basic, Delphi, etc.)?
http://digital.ni.com/public.nsf/websearch/E61ED056FB8D15D986256931006B2191?OpenDocument
Now you will be ready to run these examples, or compile your existing project which you are porting over. Check out the following Knowledge Base article which explains the necessary files. You will be using nidaq32.lib and nidaq.h.
How to Compile and Run NI-DAQ Examples with Microsoft Visual C++
http://digital.ni.com/public.nsf/websearch/C8CC0C1EA6229B09862565E90044DDF3?OpenDocumen
t
Now, what calls can you make into the NI-DAQ driver? Here's the API ...
NI-DAQ Function Reference Manual for PC Compatibles
http://digital.ni.com/manuals.nsf/websearch/1630A0B68738B269862567C1007A2912?OpenDocument&node=132100_US
Justin Britten
(3,107 Views)
