LabWindows/CVI
Using Labwindows CVI Version 10.0.1 USB communication with FTDI FT2232D to unit under test.
Communication with unit under test works fine in hypterminal after I downloaded virtual driver from FTDI site.
Never done any USB communication before in LabWindows CVI. What functions can I use in labwindows CVI?
(5,320 Views)
You may use the NI- VISA (The Virtual Instrument Software Architecture) functions for controlling your USB devices.
(5,313 Views)
Can you provide me some examples. The hyperterminal is setup using COM3 as follows: 115200-8-N-1. There is a log in command with  username and password. There are other command and I would like to read the return buffer to verify the correct response.
(5,306 Views)
Since the device presents itself as a COM port (pretty standard with the FTDI chips) you should be able to use the RS-232 library in CVI.  OpenComConfig() will open a connection to the device, ComWrt() will write data to it, and the various ComRd() functions can be used to read the responses back.
(5,299 Views)
Yes, it is working fine with the standard COM functions. Just need to work with the buffer(via LF & CR)stuff. Had to add a delay between commands.
(5,293 Views)
Having issues with not reading the full return message. Only reading sections of the return values.
(5,291 Views)
Still having issues with not being able to read all of the information. The command is "ifconfig eth0\r" but the return information is cutoff but, ok in hyperterminal.
(5,265 Views)
