LabWindows/CVI
Using Template editor in Labwindows CVI
 I would like to use ni template editor inside a program i'm developing in labwindows, for example if i have a model running in he application i'd like to edit the model like vision assistant does, i succeed in launching template editor from cvi but i'd like to open the model i'm processing and not the initial void page, coul you please tell me if there is some trick i can use to have ni template editor as a wizard inside a cvi application ?
(3,646 Views)
Hi,sorry,I dont konw how to solve your problem.I also want to use template editor to create new template in CVI.But i am just started to learning NI Vison,so I want to know how to using Template editor in CVI,and have you solve your prolem?if yes,please tell me how.Thanks !!!
(2,710 Views)
