LabWindows/CVI
Using Value as trigger??? USB 6221
Hi everybody,
I have a problem. I have 8 DO and 8 AI and I want to record my AI but I want to start recording at a specific point. For example of an rising edge of my signal which should at least reach 4 Volts. Is this possible and how to do it.
Another question is I want to know how long it is going to take my device to send out a signal and when I can receive it ( I connected DO with AI). Hoiw can I accomplish this test.
thanks for answering
(4,159 Views)
1.Before you can set the trigger use for the channel settings
DAQmxErrChk (DAQmxCfgSampClkTiming(g_AItaskHandle,"",g_d_AIFreq,DAQmx_Val_Rising,DAQmx_Val_FiniteSamps,g_i_NumOfSampelsToRead));
2.This is for the trigger....
DAQmxErrChk (DAQmxCfgDigEdgeStartTrig(g_AItaskHandle,g_c_triggerSource,g_i_triggerEdge));
3.This function will give you retrigger option....by the g_c_triggerSource ( Digital Soruce )
DAQmxErrChk (DAQmxSetTrigAttribute(g_AItaskHandle,DAQmx_StartTrig_Retriggerable,1));
Hope it helps...
Kobi Kalif
Software Engineer
(4,150 Views)
Hmm,
my Do and Ai are synced. They are using the same clock. So how do I tell my record that it should start recording when it sees a value over 4 volts.
(4,146 Views)
Hi Leee,
you only need to place the triggerfunction before the start function.
You can see it in several examples fron the LabVIEW-Examples library like the Acq&Graph Voltage-Int Clk-Retriggerable.vi.If you use an analog Edge, you can choose a channel and and a level for this function to start.
Philipp
AE | NI Germany
(4,145 Views)
youer DO needs to be read by onw of the DI in the decive then g_c_triggerSource is your DI and g_i_triggerEdge is falling or rising.
when youer seeting this function it's basiclly saing the device when you aquice and DI falling q rising start the g_AItaskHandle Task.
as Philipp said you can use alot of exmples from ni help center or the cvi examples and they will be very helpfull
Kobi Kalif
Software Engineer
(4,141 Views)
I'm sorry.
I haven't watch the toppic of this thread.
But there are almost the same functions in CVI like Kobi has mentioned.
Philipp
(4,138 Views)
