LabWindows/CVI
Using a VISA session by more than one application
The trick of duplicating handles works in Windows because their underlying memory structures are part of common system memory in kernel address space, whereas user handles reference user memory areas. It is possible to write a user driver which keeps its variables in kernel space as well, so that sharing would work, but as soon as you need access to any third party code libraries which are not written this way (eg VISA), it all falls over.
How about this as a solution to your original problem: create a third, 'multiplex' application which is solely responsible for the VISA/hardware communication handling, and make both of your applications communicate to this common one (via shared memory) when they want access to the hardware. Obviously you would need a suitable command/status protocol in place and an elementary task locking arrangement to prevent simultaneous access, but its worth taking a look at this general approach.
JR
Message 11 of 12
(1,057 Views)
Hello JR,
thanks for you suggestions. Unfortunately, one of the applications already exists and is quite complex, - so I want to avoid major changes there.
I found that the 488.2 library of NI allows access to GPIB devices from different applications. You can even initialize a GPIB device multiple times from different applciatons. I am however not sure if this is the supposed behaviour and if I can safely use it...
Anyways, - thanks again!
Greg
Message 12 of 12
(1,035 Views)
