LabWindows/CVI
Using a joystick in labwindows/CVI realtime
I have an application that may need to use a joystick in landwindows/CVI realtime.  It's been a long time since I interfaced to a joystick and I'm not familiar with what is currently available.  Can anybody recommend a joystick that will work in the NI realtime environment?  Do I need to get anything else to go with it, like an ADC card?
Thanks!
Kevin Anderson
Lockheed Martin
(4,158 Views)
Hi Kevin,
National Instruments doesn't have specific recommendations for joysticks, but one that communicates through serial would keep the determinism required by time-critical loops. You could use the Device Driver Wizard to create a driver for the joystick then use VISA commands to read movement.
USB joysticks are not recommended since USB sends interrupts even when not being used. Cheers.
Michael K. | Applications Engineer | National Instruments
| Michael K | Project Manager | LabVIEW R&D | National Instruments |
(4,130 Views)
I'm not experienced writing device drivers for VISA.  Are there any technical papers or tutorials on it?  Also, I noticed that there is something called the VISA driver developer wizard.  Is this the same wizard you referenced?
Kevin
(4,122 Views)
Hi Kevin,
If you are using a serial instrument, then you don't need to use the VISA Driver Development Wizard.  That is for PCI/PXI, USB, and Firewire devices.  If you have a serial device, the serial port should show up as a  resource on your computer (ie. COM1) and you can communicate directly to your device through the COM port with VISA functions in LabVIEW or LabWindows/CVI.  You can use your built in COM ports on your computer or serial hardware.  Click here for a detailed document on serial communication if needed.  Also, in LabWindows/CVI, you can go to Help>>Find Examples and search for VISA to find some examples on how use VISA in LabWindows/CVI.
I hope this helps you get started, but let me know if you have any questions!
Chris R.
(4,074 Views)
