LabWindows/CVI
Using *callbackData
Using the "void *callbackData" parameter in CVICALLBACK functions is great! However, is there a way to pass MORE than one structure to a CVICALLBACK function?
(3,487 Views)
You can create a higher level structure that has pointers to both structures as elements in the structure. For example,
typedef struct
} structA;
typedef struct
} structB;
typedef struct
structA* a;
structB* b;
} structC;
Then use the void* to pass an instance of C with A and B inside it.
Best Regards,
Chris Matthews
(3,487 Views)
