LabWindows/CVI
Using matlab c shared library in CVI
I'm trying to create a c shared library in MATLAB, then use that library in CVI.
Unfortunately, I am having zero success..
I have tried following the instructions given by a previous post with no luck.
http://forums.ni.com/ni/board/message?board.id=180&message.id=19209&query.id=467329#M19209
Initially, I was getting an identical problem as what is described in the post linked above. The compiler I was using in MATLAB was either "Lcc-win32 C 2.4.1" or "Microsoft Visual C++ .NET 2003", both produced the same result.
I have since got the MSVC express edition and am now using it's compiler, "Microsoft Visual C++ 2008".
This produces a .lib file which will CVI will load without reporting any errors, but at runtime I get a general protection fault when the .dll is called.
I'm at the point where I've tried everything I can think of.
The MATLAB function which I am trying to export is purely demonstrative (at this point), it simply adds 2 numbers.
-But I have not even call it in the CVI c file yet; The general protection fault occurs when CVI tries to initialise the MATLAB runtime.
I'm using CVI version 9.0 and MATLAB version 2008a (with Microsoft Visual C++ 2008 compiler)
Any thoughts or suggestions would be greatly appreciated.
Ta,
Diz.
(4,753 Views)
Hi Diz
you can find an example in:
C:\Documents and Settings\All Users\Documents\National Instruments\CVIx\samples\activex\matlab
Regards
DianaS
(4,751 Views)
Hi DianaS,
Thanks, this sample runs OK after rebuilding the ActiveX controller.
In the short-term I'll use this ActX interface, but in the longer term I still want to get the shared library working for two reasons;
(a) I need to distribute the end app to another machine, and would rather not purchase another (expensive) matlab licence, and
(b) a shared library should run faster.
cheers,
Diz
(4,727 Views)
Hello, I am having the same exact problem as Diz...
I am also trying to create a c shared library in MATLAB, then use that library in CVI.  Unfortunately, I am having zero success in CVI (works just fine in MSVC).
I have also tried following the instructions given by a previous post with no luck.
Initially, I was also getting an identical problem as what is described in the post linked above. (The compiler I was using in MATLAB was "Lcc-win32 C".)
I MSVC compiler, "Microsoft Visual C++ 2005".  This produces a .lib file which will CVI will load without reporting any errors, but at runtime I get a general protection fault when the .dll is called.
I'm also at the point where I've tried everything I can think of.
The MATLAB function which I am trying to export is also purely demonstrative (at this point), it simply adds 2 numbers.
I'm using CVI version 8.5 and MATLAB version 2008a (with Microsoft Visual C++ 2005 compiler)
Please advise; Thanks!
Andre
(4,579 Views)
