LabWindows/CVI
Using scrollbar arrows in a table's Quick Edit window expands the scrollbar
When using the Quick Edit Window to edit a table that contains a vertical scrollbar, holding down the scrollbar up or down arrow causes the scrollbar to expand to the height of the screen.  (See attached picture.)
(3,559 Views)
Hi
I can reproduce this here also.
I will report it to the developers.
Thanks for your hint.
Regards
DianaS
(3,541 Views)
Which CVI version do you use?
I think its already fixed in version 9.0.1 (but not in 9.0.0)
Regards
DianaS
(3,539 Views)
I am using version 8.5.1.
Rich
(3,536 Views)
