LabWindows/CVI
Using the 3D graph with spherical or cylindrical coordinates
I found the location for changing the 3D graph properties to accept spherical or cylindrial coordinates, but I can't find any documentation on how to enter the data.  Is this graph call correct, or do I need a different function?  I attached the wiki definations for the 2 coordinate systems.
Cylindrical
CW3DGraphLib__DCWGraph3DPlot3DCurve (graphHandle, NULL, var_RHO, var_PHI, var_Z, CA_DEFAULT_VAL);
http://en.wikipedia.org/wiki/Cylindrical_coordinate_system
Spherical
CW3DGraphLib__DCWGraph3DPlot3DCurve (graphHandle, NULL, var_RHO, var_THETA, var_PHI, CA_DEFAULT_VAL);
http://en.wikipedia.org/wiki/Spherical_coordinate_system
Ryan
(6,358 Views)
Hi ,
Please take a look at this KnowledgeBase: 3D Curve Graph and Cylindrical Coordinates
Mark E.
(6,343 Views)
I found the solution of "The 3D Curve Graph uses the mapping of (theta, z, r) into (x, y, z)", but how do the spherical coordiates map.  I don't want assume anything.
Ryan
(6,333 Views)
Also, are the values for phi and theta in degrees or radians?
Ryan
(6,331 Views)
Accepted by topic author ryan@gar
The correct spherical format is
CW3DGraphLib__DCWGraph3DPlot3DCurve (threeDgraphHandle, NULL, var_theta, var_phi, var_mag, CA_DEFAULT_VAL);
where phi and theta are in radians (not degrees)
(6,319 Views)
