LabWindows/CVI
Using the parallel port for digital output?
Has anyone found a simple way to use one of the data lines on the parallel port for digital output. I need to send a series of pulses to a bench test system to somewhat simulate a signal from 100hz to 500hz. Short of buying another daq board. I saw one in the LabView section, but wondered is someone had a simular panel for CVI.
(3,176 Views)
Here's an article for you in the NI KB.
http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/953a4ab52663089d85256427004778c4?OpenDocument
Best Regards,
Chris Matthews
Measurement Studio Support Manager
(3,176 Views)
