LabWindows/CVI
VI_ERROR_RSRC_NFOUND when trying to init scope from LabWindows
I'm running an application in LabWindows/CVI 2013 where I try to initialize communication with a LT342 oscilloscope:
 Result = IviScope_InitWithOptions (IviName, VI_TRUE, VI_TRUE,Simulate=0,RangeCheck=0,QueryInstrStatus=1,Cache=1", &ScopeHandle);
This call fails and retruns the error code :  VI_ERROR_RSRC_NFOUND (Insufficient location information or resource not present in the system).
I've downloaded drivers and setup the device in NI Max and can communicate with the scope from NI MAX. Via the I/O Trace I can see the commands being used, but the IviScope_InitWithOptions doesn't seem to be translated to lower level functions.
Is there any linking to DLLs that needs to be done from LabWIndows/CVI?
I'm new with LabWindows/CVI so please give a hint even if it's a simple mistake that You see is the root cause for the issue...
Attached are I/O trace output with communication from NI MAX (ibxxx calls) and LW/CVI.
Best regards
JOE
Message 1 of 1
(4,146 Views)
