LabWindows/CVI
VISA Resource of TPS 2024B (USB/RS232) in Signal Express
I want to connect my oscilloscope, Tek TPS2024B to SignalExpress.
I followed through the procedures in the Connectivity Installation Manual, though, failed to succeed.
I am able to connect to my device and get its identification via Open Choice Instrument Manager. It is connected with the USB/RS232 cable supplied. The port is named as COM2 in the Device Manager. I can also get waveforms via OpenChoice.
I installed the "NI SignalExpress Tektronix Step Software", which introduced a step model visible in the menu within SignalExpress.
My main problem is: Whatever I select as the VISA Resource, "ASRL2::INSTR" , "ASRL2" , "COM2" I'm notified that it is an "Invalid VISA Resource".  Autodetect doesn't work (As it is stated in serial connections), and the drop-down menu is greyed out. This is where I fail to continue with the instructions in the document.
As extra information, my IVI Drivers lack the Devices item that I have seen in many when I looked it up in this discussion board.
How can I set up my oscilloscope within SignalExpress?
Mehmet Ali Anil
(4,253 Views)
you took great effort with so many screen shots, but the response will be much better in the appropriate forum, which can be found here.
(4,250 Views)
Thanks a lot, Wolfgang.
(4,234 Views)
Hello i am using tetronix tps 2024 4 channel oscilloscope and i want to connect my pc with my oscilloscope using RS232, it would really be kind if anyone tells me which cable do i need to use for it cross cable or staright?
(4,124 Views)
It sounds like you would need a straight-through cable. You should be able to double-check that in your manual.
(4,108 Views)
