LabWindows/CVI
VarArrayCreate
Hello
I would like to know how to translate in CVI the delphi VarArrayCreate routine  that creates a  variant array   of specified dimensions and type. The result is stored in a  Variant type. I looked at the  ActiveX library but no function doing this was available. Could anybody help me.
Thanks and best regards.
Epiphane
(3,443 Views)
Hello Epiphane,
Did you look at the variant related functions ? Especially, the assigning functions, like  Variant Set 1D Array, Variant Set 2D Array, etc...
CA_VariantSet1DArray (VARIANT *Variant, unsigned int Array_Type, unsigned int Number_Of_Elements, const void *Array);
CA_VariantSet2DArray (VARIANT *Variant, unsigned int Array_Type, unsigned int Size_of_Dim_1, unsigned int Size_of_Dim_2, const void *Array);
Message Edité par Maxime MULLER le 07-09-2009 07:15 AM
(3,417 Views)
