LabWindows/CVI
Vertical alignment for label text
Is there a way to force vertical alignment for text of control labels?
This option is useful when "Size to text" is disabled (so a fixed size is specified), and the text can be on 1 or 2 rows. If there is only one row, it's quite common to see the text vertically centered.
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
Message 1 of 8
(5,909 Views)
Hi Vix,
I am not aware of an attribute that does it - but it's pretty straightforward to implement it yourself using SetCtrlAttribute (,, ATTR_LABEL_TOP,); for example, label height changes from 15 to 28 pt if a second line is added - am I correct that you're going to suggest it ? If so the new attribute could be extended to top_align, center_align, and also bottom_align Smiley Wink
Message 2 of 8
(5,908 Views)
The label text is loaded from a text file, so I don't know if it needs one or two lines.. for this reason I chose a fixed size; and the text is automatically split into two lines (if necessary).
And you're right: I'm going to write a new suggestion Smiley Wink
Vix
Using LV from 7
Message 3 of 8
(5,903 Views)
...but you could find out using ATTR_LABEL_WIDTH: display the text on an invisible label and measure its width, then compare it to the space reserved for the label...
Message 4 of 8
(5,901 Views)
Is this what you're looking for?
SetCtrlAttribute (panel, control, ATTR_LABEL_ANGLE, 900)
This rotates the label text 90 degrees.
Message 5 of 8
(5,895 Views)
Hi jared,
I'm not looking for a way to rotate the text 90 degrees.
I'm looking for a way to specify a vertical justification for the text inside a fixed size label area (i.e. if the label text is 14 px high, and the label area is 30 pixel high, I'm looking for a way to leave 8 px above the text and 8 px under the text).
Vix
Using LV from 7
Message 6 of 8
(5,879 Views)
Unfortunately, vertical justification is only available for tree and table cells. You could use a single-cell table and make it look almost like a control label, however the edges won't look the same. I don't know how much of a problem that is for you.
Message 7 of 8
(5,857 Views)
Waiting for this property in a future release, the best solution is to pragmatically move the label (as Wolfgang suggested)
Vix
Using LV from 7
Message 8 of 8
(5,844 Views)
