LabWindows/CVI
Vertical text not printing
When using PrintPanel for a panel containing a GraphControl, the left y-axis label of the graph is not showing up in the printed copy (right y-axis OK).  A very small portion of the label is visible, the remainder being clipped.  Also tried a TextMessage control turned 90 degrees as a work-around, but it suffers the same fate.  Failed on both HP and  Xerox printers.  Tried in CVI 5.0.1 and 9.0, same result in both.
Any suggestions, or proposed  work-around?
(5,137 Views)
ruskin1,
What parameters are you using in your PrintPanel function call?  And are you setting any of the print attributes before printing (using SetPrintAttribute)?  Modifying some of the print attributes (specifically ATTR_PRINT_AREA_HEIGHT and ATTR_PRINT_AREA_WIDTH or either of the offset attributes) may help put your picture in the correct place on the paper.
Eric B.
(5,120 Views)
Basic setup...
   SetPrintAttribute(ATTR_SYSTEM_PRINT_DIALOG_ONLY,1);
   SetPrintAttribute(ATTR_ORIENTATION,1);
   PrintPanel(phandle,"",1,VAL_FULL_PANEL,1);
The entrie panel prints fine except for left-y text on the graph control.  Have changed size of the graph control just in case something was covering it. Set z-plane to front, etc..  No change.  Did update the printer driver - this had no effect.
(5,115 Views)
You may be trying to print on non-printable border Have you tried with a smaller graph or moving it a little rightwise on the panel?
Also, consider this note included in the online help for PrintPanel:
Note    If the printout does not fit on the page, call SetPrintAttribute before PrintPanel to change the settings as follows:
  • Set ATTR_PRINT_AREA_WIDTH to VAL_INTEGRAL_SCALE.
  • Set ATTR_PRINT_AREA_HEIGHT to VAL_USE_ENTIRE_PAPER.
(5,101 Views)
Yes, moving the graph control so that the left-yaxis is in the center of the page makes no difference.
(5,096 Views)
If it's any comfort, you are not alone. I have the same issue with CVI 9.0(348) runtime.
It may be related to this issue, but then again it may not.
Martin
Certified CVI Developer
(5,088 Views)
I don't think ruskin's problem is related to the bug that Martin linked to, since ruskin is also having the same problem with older versions of CVI. I believe this might be a printer driver issue -- some printer drivers don't support rotated text. I haven't seen this happen in a very long time, but a few years ago I remember it happening once or twice (with Epson printers, if I recall)
There are a couple of quick tests you can do which might shed some light on this:
1. Try putting a tab control in your panel temporarily, create a couple of empty tabs in it, and change the default location for the tabs so that they are on a vertical edge (either on the left or on the right). Let us know whether the tab labels print correctly.
2. Enable the bitmap printing option and let us know what happens.
Also, can you let us know exactly which printer driver(s), including the version if possible, you saw this problem with?
Luis
(5,068 Views)
