LabWindows/CVI
Virtual Serial Driver
I am trying to establish the temperature in an enclosure using ICP-DAS modules. Those modules are at school so in order to work from home I intend to use a virtual serial port driver. I've download Virtual Serial Port Driver 7.1 and Advanced Serial Port Terminal 6 by Eltima Software but unfortunately although I've opened COM1 and I've wrote some data to be send my CVI application encounters the error port not opened. Has anyone used the virtual port simulator? are there any additional settings?
(4,389 Views)
You may be able to use a Remote Front Panel instead which would allow you to view and control the front panel of your VI from home.
(4,348 Views)
Um... Eric, we are in CVI board, here Smiley Wink
(4,336 Views)
Are you able to remotely access your computer from home?
(4,303 Views)
