LabWindows/CVI
Visual Studio Conversion Wizard Trouble
So I am running MS Visual Studio 2008 and LabWindows CVI 2010 on the same machine. I installed MSVC then CVI mainly because I need the conversion wizard. When I create a new project in Visual Studio I have the option to create a new CVI project or convert a CVI project to MSVC. However, when I select either of these options, I get the error in the image below. Any ideas?
(4,400 Views)
A reinstall did not work, by the way.
(4,399 Views)
What's the difference to your earlier post here?
I installed Visual Studio 2008 first, then CVI. I did not see the Wizard in the optional features portion of the installation, but I did find it in Visual Studio after install. Now I'm getting an error saying that CVI is not installed, despite the fact that I have both the conversion wizard and CVI project wizard running in MS Visual Studio.
(4,395 Views)
None. Just thought I'd try casting a wider net.
(4,392 Views)
Hey SummerIntern,
Thanks for using the NI Forums! To keep our forums efficient and organized, we try to limit individual problem to a single thread. It looks like you've gotten some good replies and things to try on your original thread. Please continue posting on this issue there, and hopefully you will be able to find a suitable resolution to this issue.
Best of luck!
(4,380 Views)
