LabWindows/CVI
Visual Studio / LabWindows / Alignment
I use a Visual Studio DLL in my project LabWindows.
I noticed that a unsigned int is 16 bits in LabWindows and 32 bits in Visual Studio ! So I have an alignment problem. How can I build a 32 bits application in LabWindows ?
Best Regards
(3,892 Views)
Which version of CVI are you using? Starting at least from CVI6 (I cannot go back before this version!) sizeof (unsigned int) returns 4 bytes, i.e. 32 bits
(3,881 Views)
I use LabWindows/CVI 8.0.0, and the sizeof(unsigned int) returns 2. How to have 4 ?
(3,862 Views)
Which OS are you running on? How do you examine the result of sizeof operator? Simply using a DebugPrintf in Interactive Window or mapping to a message, setting it on a numeric indicator..?
(3,856 Views)
