LabWindows/CVI
WINDOWS CE
Anybody knows if CVI ar any part of the CVI supports CE?
I saw an answer from AUG2004 that VISA has no support in CE, but what about a simple RS232 communication? What about the display control switches?
If there is no such support, any known limitation to XP mobile version?
TIA
Benny
(4,511 Views)
Currently, the CVI Runtime engine does not support Windows CE. Therefore, any major application you create in CVI will not be able to run on CE. I don't think there are any plans on migration of CVI to CE, but you can always post a product suggestion. Here's the link to submit feedback:
Product Suggestion Center
Jeremy L.
(4,496 Views)
Thanks Jeremy, Do you have any information about my 2nd question (XP embedded)?
(4,486 Views)
As far as I know, we haven't tested CVI yet with XP embedded. Not sure if it will work or not, but I have put in a request to test this for the next release of CVI.
In addition, here is another reply I've found.
Forum Post
Jeremy L.
(4,468 Views)
I am programming with CVI to control an camera, there is dll i can use, but i need an window to display the videostream, i used the imaqDisPlay function, but it did not work , can anybody help me?
Dongsheng Zhao
North China Electronic Power Univ.
zds_hd@yahoo.com.cn
(4,395 Views)
Hello toidi,
I would suggest posting a new discussion forum question on the Machine Vision - IMAQ forum.
Thanks.
Wendy L
LabWindows/CVI Developer Newsletter
(4,379 Views)
