LabWindows/CVI
Warnings by creating a lib - file
I want to create a lib-file from a dll- and h-file. By creating it, there comes a lot of warnings, that symbols from the header were not found in the dll. The symbols are all const-definitions with a value in the header-file. Can I really ignore this warnings, because I have no chanche to change it. There is also the prblem, that only 100 warnings are displayed, and I don't know whether there is another important warning, that I shouldn't ignore.
Perhaps someone has an answer.
Thanks.
(3,046 Views)
midicvi,
what kind of warnings are these? is it possible that the names of the functions are "decorated" meaning that they include many "@"-symbols and are very long?
if it is like that, you have to prevent namedecoration within the h-file. you can do that by declare the functions within 'extern "C"'-blocks.
perharps you might take a look into this link.
hope this helps,
Norbert B.
Norbert
Expert: Geometry
(3,018 Views)
