LabWindows/CVI
What Files to save in Code Management System (CMS)?
The detailed question:
What is the Miniumun set of files to store in a Code Mamgemeent System such as subversion?
The subversion admin is telling what i need and i want make sure that no files a re missed.
Thank-you  in advance.
.UIR  --- YES
.C     ---- YES
.H     ---YES
.EXE  --- no
.PRJ ---- YES
.CWS -    ????    what is the difference between CWS and PRJ?   Or where to look that explains the differences
                          in LabWindows CVI/2010 ?
.CDS  ???          What are they ?  Or where to look that explains them in LabWindows CVI/2010?
.CDB  ???
CVIBUILD.project name folder  again   What are they ?  Or where to look that explains them in LabWindows CVI/2010?
. FP  YES   - only if used in the project
,LIB  YES    - only if used in the project
Are there nay others   that you would recommend.
(3,723 Views)
hi,
 CWS - store workspace settings (multiple project, batch build,open windows and position...)
          - no,  mostly i do not have this in CMS because its is changed by every open panel in ide atc.
          - yes,Only in one situation when there is multiple project which i like to batch build  i add this to CMS (but i update this only when new project is add, not every time its changed)
 CDS  - settings to generate instalation package                             - yes
 CDB  - contain debug information for exe file                                  - no,like exe it is not need to be store in CMS
 CVIBUILD.* this directory(+subdirectories) contain files that are generated during code compilation           - no
 CVIDIST.*   this directory(+subdirectories) is default path for generated instalation package                - it depends on you, i have this in separate repository
if there is any file that is used by program and/or is ditributed within instalation package, it is good to think abou it.
For example .DLL .INI .CFG .DATA .ICO .BMP manual.pdf (most of this [INI,DATA,manual.pdf] i have in separate directory named InstallData to not mess this with actual working data)
I also have whole project documentation direcory in separate repository but that depends on situation.
BTW. CMS i use is GIT (msys not the cygwin one), it is not integrated to CVI IDE, but works well for me 🙂
         I like to sync my wohle work to notebook, work and commiting change offline and then sync back to main development PC
(3,718 Views)
As an addition: tracking .tui in addition to .uir  files makes it easier to diff changes in the user interace.
http://forums.ni.com/t5/LabWindows-CVI/Version-control-and-uir-files/m-p/2765164/highlight/true#M659...
(3,311 Views)
