LabWindows/CVI
What causes "A Run-State Change Callback" protection fault.
Hello!,
I'm maintaining some DAQ C++ code that I didn't write and it has an odd bug... Whenever we close the application, an error dialog appears with "LabWindows CVI" in the title-bar. The error text is "A Run-State Change Callback caused a protection fault." When compiled, the app. _probably_ draws from some ni device-driver, or one that was built with LabWindows CVI. Anyway, I'd like to make this dialog go away. Any ideas are appreciated!
(2,910 Views)
Run State change Callbacks are discussed in our CVI manuals and our Knowledgebase here. I couldn't really say why your application is getting a protection fault in the callback, but you must be using the CVI run-time engine. The callback was used in the CVI envinronment for determining the run-state in debugging.
Hope that information helps,
Chris Matthews
(2,910 Views)
